Denon 1705 vs Pioneer 811 vs Pioneer 714
Discussion in 'AV Receivers & Amplifiers' started by andrew1810, Oct 16, 2004.
Tags:
  1. andrew1810
    andrew1810
    Apr 4, 2004
    1,179
    North East
    +55
    Which of the above amps if better for movies?
    Want PL2 and preferably DTS-ES or another 6.1 option for the future (7.1 would be a bonus)
    Only need 1 optical and 1 co-ax for Pioneer DV444 and Nokia Freeview Box
    Will be using Wharfedale WH2 rears and centre and Kef Coda 7 Fronts. Definitely want binding posts.
    Andrew
  2. andrew1810
    andrew1810
    Apr 4, 2004
    1,179
    North East
    +55
    Also, how would these compare to a cheaper 4300?
    Andrew
  3. Dfour
    Dfour
    Jan 19, 2004
    4,091
    71
    Bracknell
    +86
  4. andrew1810
    andrew1810
    Apr 4, 2004
    1,179
    North East
    +55
    I can manage the denon as its only £180 at unbeatable but the Pioneer 814 is just too far over budget I think, I can afford the 714 but not the 814
    Andrew
