Denon 1601 Coax and Optical
Discussion in 'AV Receivers & Amplifiers' started by richjthorpe, Jan 19, 2005.
Tags:
  1. richjthorpe
    richjthorpe
    Aug 2, 2004
    2,031
    41
    dat london
    Hi all,
    I've got a Denon 1601 (It feels so ancient now there is the 5fth generation of these !) and I wondered if it was possible to set the Coax and Optical sound inputs to switch depending on the input.
    The problem I have is that I want to connect the DVD player via Coaxial and the PS2 via optical, but I have a feeling you can only use one at any one time.
    I'm guessing not many people have the 1601 anymore, so how do the other Denon amps deal with this ?
    Thanks,
    Richie.
