Denim AVR 1910 keep separate subwoofer volume setting between sources
Gr1f
Hey all,
So I’m happy with sound settings once I set up the amp for DTS/Audessy for video source. My other primary use is as 2.1 for audio that I serve via a DAC and another via phono stage. I have these inputs set to Direct and L/R set to small and sub set to LFE+Main.
I have each source added to a quick select.
Thing is I have to manually adjust the subwoofer each time I switch source using the CH Level button on remote.
is there a way to make sure all direct sources maintain same subwoofer level?
Fudging around the menus doesn’t seem to find anything specific.
Thanks!
AVForums Movies Podcast: We review Dune and ask which is the best decade for horror movies?
