Demystifying Video Formats
Discussion in 'Blu-ray & DVD discs' started by m4rtyboy, Feb 16, 2014.
  1. m4rtyboy
    m4rtyboy
    Jan 14, 2009
    142
    16
    Hello
    I am trying to demystify movie formats and try not to create hours of work for myself.
    I have hundreds of movies in a TS format using Any DVD as I wanted to retain full quality and
    I now want to look at streaming my content to other TVs in the house with some kind of attached media streamers, maybe a WD TV Live.
    My moves are stored on a HTPC downstairs and I use My Movies. I dont care about having the same fancy user interface but just want to be able to watch them without stutter.
    I have just started to read about MKV and have used Make MKV to transfer a few of my TS into MKV. Having a consistent format to be able to use across multiple devices would also be useful so is MP4 better as this could be used for tablets etc.
    One issue I have come up with MKV is that I have a cheap Chinese media player attached to my daughters TV upstairs and when I transfer a file to MKV and copy this to the SD card it wont play. I know its not the device as it wont play from the SD card from any device. However if I transfer to a separate hard drive, I am using a Western Digital and attach it to this cheap player it does work. So in essence it wont play from the SD card from any device, strange!!
    So I was looking to get a WD TV live and see if that will connect to my PC network and play my current TS content as it does say that TS is a supported format.
    So where should I go from here? Am I better off transferring all these TS to one of these other formats? Or just leave it be?
    I also used Make MKV to transfer a Blu Ray and was really surprised that this worked as I thought it would have had some kind of encryption (whilst I have Any DVD, I dont have Any DVD HD for Blu Rays). The resulting file was 30GB which I then encoded with Handbrake and got it down to 10GB. Do I lose much quality doing this, I certainly could not tell too much. With all these questions I dont really want to lose too much quality.
    There is so much conflicting advice but would like to hear thoughts
    thanks
  2. probedb
    probedb
    Aug 20, 2003
    2,660
    Sheffield
    +180
    MKV and TS are just containers, they contain the same audio/video. You're just outputting to a different container. I have an Oppo BDP-93 and that doesn't support HD audio in an MKV container.
    What you do depends on your ultimate aim really.
    I don't see why you'd buy a Blu-Ray then compress it and use that to watch, surely the whole point is the quality and by recompressing you're just lowering it. Whether or not you can see if a different matter.
    So for me:
    - DVDs, always mkv
    - Blu-Rays with no HD audio, always mkv
    - Blu-Rays with HD audio, always m2ts.
  3. m4rtyboy
    m4rtyboy
    Jan 14, 2009
    142
    16
    how do i know if a blu ray has HD audio and by this do you mean 5.1
    thanks
  4. hippo99
    hippo99
    Feb 29, 2008
    16,716
    163
    +9,829
    HD audio- ie TrueHD, DTS-MA, PCM (in early Blu-rays).
    Just look on the back of the box to see what audio is on the Blu-ray.
