Demo'ing a Denon 3800
buzlightyear
Got a demo for one of these bad boys now and will take an array of DVD's with me...Toy Story, Monsters etc....
I will see if i can spot any problems and see if i can get the firmware number. Its meant to be a MR machine as well.
Just a little question.
How do you get the firmware numbers up?
I will check the s/n as well.
Buzz
(To Infinity and possibly a working 3800) :D
gringottsdirect
1. Power unit off with main on/off on front panel.
2. While pressing together " Play " and " Open / Close " buttons on front panel, power unit on with main switch on front panel.
3. In the display you will see the Play and Pause symbols.
4. Now, using the remote, press " Menu " button. With each press you will scroll through the different versions of the unit.
DRV - ESS - Panel...
5. Power unit off with main switch on front panel.
That's it, but the dealer should do it anyway for you.
