Demo'd an HS10.......disappointed
Discussion in 'Projectors, Screens & Video Processors' started by spiderv6, Feb 20, 2003.
  1. spiderv6
    spiderv6
    Dec 12, 2002
    138
    16
    Well, I finally was able to demo an HS10 this week and I was a bit disappointed.
    The room I saw it in wasn't perfect (i.e. there was a lot of ambient light) but I guess it was not too far from the average living room.
    My biggest disappointment was the quality of the image while up-close. This was very fuzzy (or 'soft') and not atall what I expected. Obviously from further back this was much less apparent. It wasn't running in progressive scan mode (which is what I would do) but through the PJ Multi wire - maybe that's part of the reason (?)
    The screen door effect that we hear so much about was non-existenet as far as I was concerned. That was the most impressive thing. Individual pixels were pretty hard to pick out.
    The noise - yes it's noisy. Switching to cinema mode did halve the noise levels to an acceptable amount but that also makes the image quite a bit less sharp/bright.
    I had every intention of leaving the shop with an HS10 but I just wasn't happy with the quality to make a decision. I need to now look higher up the price chain to see if paying more makes a big difference.
    This is the first PJ I've ever seen demo'd and I know little about PJ's but I'm afraid it just didn't match my expectations.
    I'm glad I didn't take the plunge and just order one now!
  2. nathan_silly
    nathan_silly
    Did the guy perform a focus?
  3. Comer
    Comer
    Sep 21, 2001
    1,365
    Ireland
    +83
    I'm surprised to hear this. My only two complaints about this pj are its noisy fan and black level could be better.
    As far as a fuzzy image is concerned I found that this projector gives a very sharp image even from svideo. How close to the screen were u when u found the image fuzzy?
    Conor
  4. John_N
    John_N
    I'm surprised by this too.
    I own the HS10 and I find the picture quality very high for a unit in this price range. I don't find it 'soft' or 'fuzzy'. The only thing I can think of is that either:
    a) it wasn't focused.
    b) You were viewing a large image too close.
    c) The source material was exceptionally poor - like VHS for example.
    From my normal seating position 2.8 metres from a 180cm wide screen, I find the picture very sharp and nothing to complain about.
