Demo of TH-42PHD5
Discussion in 'Plasma TVs Forum' started by DJP, Jan 20, 2003.
  1. DJP
    DJP
    Jan 10, 2003
    74
    Hampshire, UK
    +5
    Does anyone know of a supplier with a Panny TH-42PHD5 on display? I've tried NexNix but they only have the standard resolution model.
    I'm trying to decide between the TH-42PHD5, the TH-42PW5 and the Pioneer 433MXE.
    As it'll be 90% Sky+ and 10% DVD (I will be updating the DV88 to DV88+ to get prog ressive scan) I'm also considering adding the IScan Ultra to the set-up. I guess that the question is whether the higher definition Panny is worth the extra grand.
    Thoughts and comments appreciated.
    Derek
    PS Lowest I've seen the TH-42PHD5 is currently 4253-50 inc the BNC card. Anyone seen it lower?
