Demo-ing in Hampshire
Discussion in 'Projectors, Screens & Video Processors' started by CooperUK, Jun 13, 2003.
  1. CooperUK
    CooperUK
    Am interested in buying a PJ for approx £1000.
    Anyone know of any places in Hampshire I can go to find out/demo etc.
    I have found an InFocus LP500 for £1200 with an extra lamp and 3yr warrantee, but have not seen it in action.
    Is a contrast ratio of 400:1 good enough? It has 2000 ansilumens
  2. Hawklord
    Hawklord
    Feb 15, 2003
    3,432
    Aldershot, Hampshire
    +260
    Audio-T have a Demo room in their basingstoke branch and are also in Camberly I believe. Give them a ring and see if they can help you out - Tel 01256 324430
  3. edz
    edz
    Oct 10, 2002
    237
    Back in Bournemouth
    +20
    That's a damn good question. When I lived in Hampshire, (now moved to dorset), and was looking for a proj' the first time, (was put on hold due to a house purchase then another move, then a girlfriend, then a wedding :eek: , then two more moves....), I couldnt find anywhere either. Only now getting an AE300 .. or at least waiting for one from nexnix...
    Where in Hampshire are you ? I lived in Southampton/Gosport for around 18 years and around there the best chance I *THINK* you have will be either (A) Richer sounds if you book ahead at their Southampton store, (B) John Lewises in west key southampton - definitely have plasmas not sure about projectors, or (C) Sevenoaks in southampton - just up the road from Richer sounds in fact. I'm happy to be corrected if anyone knows of any other locations though.
    If you have loads of dosh you could also try Dawsons in westbourne, (this is actually bournemouth/dorset but is only up the A31 from southampton), but they are more custom installs than boxed units...
    Best of luck, let us know how you get on...
    Edz
  4. rahulkohli
    rahulkohli
