delta 270
grahamfocal
Hi there I am a new member gooday to all.:lease: http://www.avforums.com/forums/images/smilies/xyxwave.gif
:hiya:
I have a delta 270 cd player and in desperate need of a new drawer mech. a gear inside that opens the drawer has, well turned into a non toothed variety, so the drawer fails to open, can anyone help.
Also does anyone know of where I can get a mint (new) faceplate for it, a few scratches are driving insane.
thankyou anyone. (from loverly, but wet somerset)
http://www.avforums.com/forums/images/smilies/eek.gif
:eek:
Carl Stock
Hello there! :)
I am only guessing here by looking at a picture of a Delta 270 with its tray open, but I am 99% sure it uses a Philips CDM9 mechanism.
It is not uncommon for these mechanisms to basically chew through their teeth (hehe!) after a few years, and it should be a case of replacing the ‘wheel'. I did this by salvaging one from a Philips CD player to fix my Alpha 5+, as they share the same CDM9 mechanism.
You can get new part from here, for example:
http://cgi.ebay.co.uk/PHILIPS-CDM9-LOADING-GEAR-WHEEL-ARCAM-THETA-MERIDIAN_W0QQitemZ230009663198QQihZ013QQcategoryZ3272QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
Note that I have no connection with the above seller, and I have not used them.
Hopefully, that will help with that problem.
I am not sure about the other issue of the stratched fascia, so I will leave that up to others! :)
Regards,
Carl :)
