Sicoe
Established Member
Hi All
I turned the above monitor on today and for 5 seconds made a little humming noise, it then went and the screen display dissapeared however the monitor light was still on.
i have checked dvi and hdmi and vga connections, power connections, different leads the lot.
even used the monitor on its own, basically ill turn the monitor off and on again, ill get the humming sound for 5 seconds a picture for 5 seconds and then nothing, but the light is still on.
anyone come across his or have any suggestions.
trouble is i cant find any info of the purchase or know if its under warranty.
help
regards simon
help
regards simon
