Dell PC & poor HD picture.
Discussion in 'General TV Discussions Forum' started by leedsfireman, Jul 22, 2004.
  1. leedsfireman
    leedsfireman
    Mar 21, 2002
    1,232
    38
    +3
    Hi, I have a Dell PC, pent4 3.02ghz, 1gig ram, 128mb grahic card & 17" Dell HiDef monitor connected via DVI.
    But i must admit the picture quality i've seen using Wmv & some HD discs i've got are not impressive at all.
    The picture seems very soft & fuzzy, can any one give me some pointers how to check if my set up is right.
    Andy.
  2. Deron
    Deron
    Sep 11, 2002
    371
    +15
    Have you tried the clips from MS?
    How do they look? Water based ones are normally good indicators as to picture quality.
  3. leedsfireman
    leedsfireman
    Mar 21, 2002
    1,232
    38
    +3
    Hi, yes i've tried the MS clips, ie the dolphin one, but like i said the quality is not all that good. It is not sharp & seems soft with no detail.
    I was especting a WOW picture, i hope that it is just down to some wrong settings.
    Andy
  4. MR151
    MR151
    Have you tried adjusting the contrast on your monitor? What monitor do you have? Every so often, it will need adjusting.
  5. Messiah
    Messiah
    Apr 22, 2002
    7,624
    +338
    What is the resolution of your monitor? If it is not the same as the clip/s you have watched then the additional scaling being performed could well be the cause of the softness and fuzziness.
    I have a 1280x768 PC monitor and HD material looks OK at best. Play it on my 1280x720 pj though and it's a completely different story. Pin sharp.
  6. Starburst
    Starburst
    Jul 13, 2000
    17,846
    Ilkeston
    +975
    I have to say that the quality of all the HD material I have played on my PC has been simply stunning, even on a very old 15" 1024*768 monitor, taking into account the amateur status of some of the WM9 encodes of course.
    Currently running a 19" 1280*1024 LCD monitor and the image quality has gone up a couple of notches over the crt monitor and when I finally get round to upgrading the PC I can play the 1080i TS and WM9 caps smoothly:)
  7. Deron
    Deron
    Sep 11, 2002
    371
    +15
    Hidef is stunning on a lo res plasma so anything higher res should be more impressive.
  8. venkman
    venkman
    Jan 17, 2003
    82
    Keighley
    +4
    Well, they look stunning on my 1920x1200 laptop. I would agree with the post above to check you are running at the native resolution of the monitor. Also check if video acceleration is enabled.
  9. philjames
    philjames
    Dec 20, 2002
    22
    3
    Swindon, UK.
    Do you have FFDSHOW installed by any chance, it could have been installed with a codec pack. There are settings (filters) in there that could be softening the image, although i've not come across an install that will soften by default.
    Also, check your overlay settings for video contrast, brightness etc,. + check any anti-aliasing settings on your video card, they may be effecting it?? :confused:
    In situations such as this, everythings worth a fiddle.......... :) :laugh:
