Dell 790 DT
Discussion in 'Computer Components' started by WazKayani, Jan 10, 2012.
  1. WazKayani
    WazKayani
    Aug 14, 2006
    112
    Surrey, UK
    Guys
    I have a Dell 790 DT and need to put a good GFX card in it. The kids like to play games on it although not the latest but it would be nice to play some of the latest stuff. I appreceiate with the PSU (250W) and limited size, I wont be getting the latest/greatest GFX cards but can someone give me some guidance on which would be good. Specs below. I have 16Gb of RAM in the PC also. I dont want to really purchase a new PSU and case if I can help it.
    DESKTOP (DT):
    Dimensions (H x W x D) Inches/(cm):
    14.17 x 4.02 x 16.14 /
    (36.0 x 10.2 x 41.0)
    Min. Weight (lbs/kg):
    16.67 / 7.56
    Number of Bays:
    1 internal 3.5"
    1 external 5.25"
    Expansion Slots:
    1 half height PCIe x16
    1 half height PCIe x16 (wired x 4)
    1 half height PCI
    Power Supply Unit (PSU):
    Standard 250W PSU or optional 250W up to 90% Efficient PSU; Energy Star 5.0 compliant, Active PFC
    OptiPlex 790 Desktop Details | Dell
    Thanks guys
  2. LJx
    LJx
    May 29, 2009
    3,259
    uk
    +437
  3. WazKayani
    WazKayani
    Aug 14, 2006
    112
    Surrey, UK
    Thanks LJx for the help.
    I checked on the DELL site and started configuring a 790 DT and it gives you the following options:
    512MB AMD Radeon HD 6350 (Half H., DMS59 + cable for 2VGA) [add £81.00]
    512MB AMD Radeon HD 6350 (Half H., DMS59 + cable for 2DVI) [add £84.00]
    1GB AMD Radeon HD 6450 (Half H., 1DP & 1DVI-I) [add £117.00]
    1GB AMD Radeon HD 6450 (Half H., 1DP & 1DVI-I, no adapters) [add £105.00]
    Dual 512MB AMD Radeon HD 6350 (Half H., 2cards w/ DMS59 + cable for 2VGA each) [add £162.00]
    Dual 512MB AMD Radeon HD 6350 (Half H., 2cards w/ DMS59 + cable for 2DVI each) [add £168.00]
    Dual 1GB AMD Radeon HD 6450 (Half H., 2 cards w/ 1DP & 1DVI-I each) [add £223.00]
    Dual 1GB AMD Radeon HD 6450 (Half H., 2 cards w/ 1DP & 1DVI-I each, no adapters) [add £211.00]
    Matrox
    Matrox M9120+ LP PCIe x1 Dual Port Graphics Card [add £288.00]
    The GFX you mentioned - is that better than the above ?
  4. LJx
    LJx
    May 29, 2009
    3,259
    uk
    +437
    Yes it's the model up from the 6450. the options at the bottom of the list I think are talking about adding two of the cards and I am not sure exactly how that would work (if they would be independent or in crossfire.
  5. WazKayani
    WazKayani
    Aug 14, 2006
    112
    Surrey, UK
