Dell 2200MP Lamp LIght
Discussion in 'Projectors, Screens & Video Processors' started by avo, Aug 6, 2005.
  1. avo
    avo
    Aug 6, 2005
    5
    HI can any one help !!
    i have a dell 2200MP and was working ok for a few hours it had 1650 hours left on the lamp and as sadly gone out of its 12 months warrenty the lamp light now lights up orange and is telling me the lamp as gone i have no way to check this but i dont think the lamp as gone it looks fine and dont look blown i think the projector as a fault
    my question is when i connect a multi meter to a projector lamp should it read short circuit just like a standard bulb ?
    as anyone else had this fault and not turned out to be the lamp?
    thank you in advance ..
  2. thescoobydoc
    thescoobydoc
    Dec 2, 2004
    134
    +16
    I think i may have already answered your question when you asked via my website, one other thing i can suggest is, if you are suitably qualified and you have a meter, is to check the lamp pins on the projector for a voltage reading.
    Obviously if you get a voltage reading then the chances are it is the lamp that has gone, other than that all you can do is what i previously suggested.
    Regards
    Sean
