Dell 20" monitor and S-Video - black and white pictures
J
jbatty
I am trying to connect my freeview (terrestial TV reciever) box to my DELL 2007WFP monitor. The freeview box has SCART out and the monitor has S-Video in. So I purchased a good quality SCART to S-Video cable. Unfortunately, the monitor only shows the pictures from the freeview box in black and white .
The same setup (i.e. the freeview box with the SCART to S-video cable) worked well in full colour when I connected it to my 3 year only Sony Wega TV.
What setting do i need to change on the monitor to obtain full colour? I have tried changing the resolution but to no avail.
Any suggestion will be appreciated.
J
jbatty
Thanks for the reply.
The freeview box is a Thomson DTI 1000. The freeview box's software menu offers 2 output options. "PAL" and "RGB". It defaults to RGB. I have tried both options with the monitor but no luck.
However both options work with no significant difference when the box is connected to the TV via the SCART to S-video cable.
J
jbatty
I have tried using a Sony DVD player with a SCART out with the cable and then connect it to the Dell monitor. I am still getting Black & White pictures. This leads me to believe the problem is with a setting on the monitor.
SeanT
Neither the freeview box you mention nor any basic DVD player will output s-video via scart - the WEGA must be detecting composite over s-video signal and routing it appropriately - a basic svid-svid cable will solve this, if the fv box has svideo out
J
jbatty
Thanks for the response, SeanT. The freeview box does not have any output source apart from the SCART. From your observation it appears that I have to do one of two things to watch freeview of my Dell monitor.
1. Keep my current freeview box and get a SCART Out/Composite video in cable. The monitor also has Composite video input. Is it possible to determine whether my freeview box / basic dvd player will output composite video over SCART, before I buy the cable?
2. Get a freeview box/tuner that can output s-video out. Do you know any such box currently on available on the UK market?
A freeview card is not suitable as I need to be able to watch TV even when the PC is off.
SeanT
The Sony VTX-800 (I think it's called) and the Netgem Iplayer both did iirc - my brothers each have them so can check again (guess who bought their freeview boxes!) - BT Vision has so I'm guessing that the majority of twin tuner pvrs do - and pretty much every freeview enabled DVD recorder will.
