For Sale Dell 1U dual Quad Low Power Server ESXI 5.1 compatible
Discussion in 'Archived Classifieds' started by lightningslow, Aug 6, 2013.
  1. lightningslow
    lightningslow
    Mar 7, 2013
    461
    +27
    No longer needed as was experimenting with it.
    ESXI 5.1 is already installed and is licensed ready to go, Can reset login and password to users choice. If you prefer i can also install a lower version.
    Has 3x sata 320gb in a non raid config (but software raided and does support hardware raid of 0 or raid 1) with 8gb of ram in 8 slots in a 8x1GB configuration leaving 8 slots free. 16 slots that support up to 128GB of DDR2 ECC.
    Noise level is pretty quiet at idle with moderate at full load.
    Low power Xeon L5410 2.33 Ghz with 24MB of L2 cache between the chips. 8 physical cores in the server.
    1x Full length 16x PCI-E slot with riser attached to the server as well.
    SATA supports 3TB disks and has 1 single non redundant psu
    I need this to be picked up please as its heavy and i dont have a box. I can also deliver within 50 miles of the M25, so please contact me for rates
    Price I'm after is £200
    I have read the trading rules and agree to abide by them at all times until the transaction is concluded to the satisfaction of all parties involved : Yes.
    This message is automatically inserted in all classifieds forum threads.
    By replying to this thread you agree to abide by the trading rules detailed here.
    Please be advised, all buyers and sellers should satisfy themselves that the other party is genuine by providing the following via PM to each other after negotiations are complete and prior to dispatching goods and making payment:
    1) Landline telephone number. Make a call to check out the area code and number are correct too!
    2) Name and address including postcode
    3) Valid e-mail address (no disposable addresses such as @gmail or @yahoo for example).
    DO NOT proceed with a deal until you are completely satisfied with all details being correct. It's in your best interest to check out these details yourself.
    Also we advise that the vendor post images of the items for sale. This helps your sale by showing the condition of the goods prior to dispatch.
  2. lightningslow
    lightningslow
    Mar 7, 2013
    461
    +27
  3. chukwe
    chukwe
    Aug 15, 2009
    5,130
    Welling, Kent
    +465
    How many cpu can it take? And what part of London to you stay?
  4. lightningslow
    lightningslow
    Mar 7, 2013
    461
    +27
    it can take two physical chips up to L5430 and I haven't tested it with the non low power versions, but i suspect it will not boot as the PSU will need to be beefed up significantly as the power draw will be double as will the noise if not higher. It has two L5410 at the moment.
    Im based around the east end most evenings
  5. lightningslow
    lightningslow
    Mar 7, 2013
    461
    +27
  6. highpriest
    highpriest
    Nov 23, 2008
    831
    Winchester
    +51
    What is the Dell model number? How many on-board NICs does it have? Would you happen to know the approximate power draw at idle, medium load and when pushed?
  7. lightningslow
    lightningslow
    Mar 7, 2013
    461
    +27
    Three on board of two gigabit and 1 10/100 management port. It's a dell cs23 which is a custom server and like the poweredge but without so much expense as they're used in cloud clusters mainly.
    Power draw depends on a few things really. Hard disk installed and type, ram slots occupied and what you call idle and under load. It's not a 0.3a server as its got two chips so its between 0.4 and 0.5 at idle and full throttle it hasn't been clocked at over 1.2amps but I did have 16 vms running at once with 100% tanked out on the chips with triple ssd. Your load may vary though
  8. highpriest
    highpriest
    Nov 23, 2008
    831
    Winchester
    +51
    Thanks, let me have a think. Will get back to you.
  9. chukwe
    chukwe
    Aug 15, 2009
    5,130
    Welling, Kent
    +465
    What's the weight? What part of East London do you stay?
    I'm currently working in Brentwood, Essex.
  10. lightningslow
    lightningslow
    Mar 7, 2013
    461
    +27
    between 25-30KG and im based in Basildon in the evenings so im happy to drive up to you (or down) to deliver it for you? Im at Tower Hamlets in most of the day. Its easier in the evenings though as work is hectic at the moment.
    I also dont have a box so courier shipping this is out of the question unless you want pallet rate which is very expensive so cheaper for me to drive it down to you.
  11. lightningslow
    lightningslow
    Mar 7, 2013
    461
    +27
  12. lightningslow
    lightningslow
    Mar 7, 2013
    461
    +27
  13. lightningslow
    lightningslow
    Mar 7, 2013
    461
    +27
    highpriest any info on your ponderings?
  14. highpriest
    highpriest
    Nov 23, 2008
    831
    Winchester
    +51
    Still thinking :D
    Thing is, I can't decide whether to go for a proper server class machine or build a pair of quiet hosts using desktop class hardware (using something like the Shuttle XH/DS slim PCs). I need it to be as quiet and efficient as possible :)
  15. lightningslow
    lightningslow
    Mar 7, 2013
    461
    +27
    Thats not an issue. I am biased however in that these are designed for low power whereas a desktop isn't and i have run 16VM's on them with ease.
    At idle its about as noisy as a desk fan, at full load its a little louder and like a portable air conditioner. But as its so efficient its never at 100% for long.
    You can build desktop machine, but this is built for the purpose of being as efficient as possible.
    If you want, ill take out the 32GB of ram and leave it with 8Gb and you can have it for £200.
  16. lightningslow
    lightningslow
    Mar 7, 2013
    461
    +27
  17. lightningslow
    lightningslow
    Mar 7, 2013
    461
    +27
    Chukwe, your priestness, what update?
  18. lightningslow
    lightningslow
    Mar 7, 2013
    461
    +27
  19. highpriest
    highpriest
    Nov 23, 2008
    831
    Winchester
    +51
    I've decided to go down the custom Haswell route. I'll withdraw my interest. Good luck with the sale!
  20. lightningslow
    lightningslow
    Mar 7, 2013
    461
    +27
  21. lightningslow
    lightningslow
    Mar 7, 2013
    461
    +27
    last bump before it gets pulled :)
