Dell 1703FPs
Discussion in 'Plasma TVs Forum' started by bob mushroom, Dec 22, 2003.
  1. bob mushroom
    bob mushroom
    Jan 26, 2003
    790
    +22
    I currently have this monitor attached to my PC but am looking to change to a mac so will be redundant.
    As a good picture (on PC) I am wondering 2 things and perhaps you may help.
    1) Is it possible to turn this into a tv for the bedroom? I understand that tuners can be bought but how do they connect? I have 4 USB ports on the monitor and the usual VGA port and a DVI-D port (unsure what this is.) I can attach a speaker set to the screen (seperate attachment) through Dell.
    2) The monitor is wall mountable but I do not have a bracket and Dell do not seem to sell them - how easy is it to find a bracket that will fit? Where do I start looking?
    Mny thanks for your help
    Bob
  2. wb1
    wb1
    Sep 5, 2003
    1,673
    38
    London
    +21
    Bob,
    This is what you need to turn the monitor into a tv.
    http://www.avforums.com/forums/showthread.php?s=&threadid=89014
    By the way the DVI-D is a digital video interface for a PC with digital video output.
    If you want a wall bracket (it's called a VESA wall bracket send me a PM as I can supply these - I'll have to check the price.
    Regards,
    William
