DVDpedia sounds like a great little program. My collection's getting so large that I'm starting to forget what I've got. Is the bar code reader (using iSight) really that good? And is it worth paying the registration fee (not sure what it is in gbp)?
I've been playing with the trial versions of both DVDpedia and Delicious Library over the last few days, and I can say that the iSight scanning in DVDpedia is far better than DL.
DVDpedia seems to just require a quick glance of the barcode and it's got it - sometimes it's done it so quick I didn't realise it! On the other hand, DL is very fussy - you have to hold the barcode much closer, and line it up perfectly.
At the moment DVDpedia is around £12 (although will probably have to add VAT on to that), whereas DL is just over double that. Saying that, DL lets you catalogue more than just DVD's, but then you could get some of the other pedia apps if you needed them.
I'm fairly certain I'll opt for DVDpedia, as:
1) Thats the only thing I have enough of to warrant cataloguing (except CD's, but they're all in iTunes now).
2) Half the price
3) Barcode scanning much better
4) Generally prefer the GUI better. Feels more intuitive and looks better
Douglas
