Deleting
alan.b
i've always used DVD RAM discs, but, i am about to record on my panny DMR50, using-R discs, can i delete the adverts on these?:(
ROYOLD
Never used anything but DVD-R and DVD-RAM in my Panasonics.
However - according to this website the DVD-RW discs behave like a CD-RW. You must erase the entire disc and start over again. Only the DVD+RW discs can be edited like DVD-RAM. Perhaps you would be better off sticking with DVD-RAM - I don't think the Panasonics fare well with DVD+RW.
DVD-R use a different dye than DVD+/-RW and with DVD-R the recording is fixed. You can NOT edit out adverts after recording. Only erase the entire programme, and if you ERASE then the space erased cannot be re-used.
http://en.wikipedia.org/wiki/DVD+RW
ChainsawDude
No you can't.
These are recorded as dvd-video on panasonics so there is very little editing allowed even with dvd-rw, and you will get the WSS problem. I recommend you stick with dvd-ram.
Gavtech
Administrator
It would appear it is not possible.
To do it you would need to use partial erase and the manual implies that this is a RAM only function.
I believe whole title erasure is possible, so I dont know whether a possible workaround would be splitting titles up into programme segments and adverts , then erasing the ads... but it would be cumbersome and messy.
Podcast: CES '22 TV Announcement Round-up, Plus, Most Anticipated Movies of 2022 and More...
