Deleting unwanted Channels on Sky
Discussion in 'Sky Digital TV Forum' started by asa_5, Aug 21, 2005.
  1. asa_5
    asa_5
    I have a Panasonic DSB30 box, all the channel are preset, for example Sky new is on channel 501 and bbc world is no 507.
    I dont have sky subscription therefore, there are many channel I cannot view.
    I would like to sort the viewable channels.
    How can i do this? how to delete other channels
    thanks
  2. johndon
    johndon
    Feb 3, 2002
    1,971
    63
    +108
    You can't delete channels from the EPG - unlikely to happen either AFAIK, the channels pay Sky to show their listing so they are hardly likely to allow users to delete them.
    John
  3. ParmMann
    ParmMann
    Dec 6, 2004
    941
    28
    +50
    Your best bet is probably to set all your viewable channels as favourites.
    That way, pressing the blue button will take you from viewable to viewable channel.
  4. Heinz
    Heinz
    Aug 4, 2005
    408
    Earle Colne, Colchester
    +15
    But you'll have to be selective - the blue button favourites list is limited to 20 channels - and you have many more than 20 FTA channels available.
  5. ParmMann
    ParmMann
    Dec 6, 2004
    941
    28
    +50
    Yeah the way I use the favourites is to assign one favourite channel at the start of a group of channels.
    So I have like BBC1 as a favourite, then don't need 2, 3, 4 or 5 cause I can just press up to get to those. SKY Movies 1, then just press up to get the rest. Sky Sports 1 and so on and so on.
  6. ZippyCat
    ZippyCat
    Aug 9, 2004
    573
    28
    +22
    That’s the idea I had, but you have got to admit that the inflexibility of Sky’s EPG is very annoying. There seems to be more and more channels every month added, non-of which are worth watching and its only going to get worse. It’s got to the point where I am going to cancel Sky, as I can’t stand sifting through hundreds of channels. I really wish you could customise the EPG.
  7. Starburst
    Starburst
    Jul 13, 2000
    17,838
    Ilkeston
    +975
    The EPG is only as bad as you allow it to be, if you focus on it's short comings then you will never accept it or learn to use it well.
    You soon learn the EPG numbers of your favorite channels and you really have to be bored to channel surf the whole EPG although it does make an interesting journey as long as you are a subscriber and therefore have access to most channels:)
    If the EPG layout is enough to make you consider cancelling then I would say that is just the most obvious symptom and you are not happy with other aspects of the service.
