Deleted all tomtom files.. help?
Discussion in 'ICE, Sat Navs & Dash Cams Forum' started by ant_j, Feb 4, 2009.
  1. ant_j
    ant_j
    Aug 31, 2007
    2,571
    71
    Derby
    +81
    My dad has a tomtom one (i think a v2, will check).
    And somehow when hooking up to his pc as mass storage managed to delete all files including hidden system ones :suicide:
    Is there anywhere to get these back from?
    Will tomtom supply? Where does he stand regarding map file and
    activation?
    What a plank! Any help greatly appreciated!!
    :rolleyes:
  2. diandave
    diandave
    Jul 2, 2006
    138
    Staffs
    +9
    Try pressing the reset on the bottom of the unit, this should do the trick......:smashin:
  3. ant_j
    ant_j
    Aug 31, 2007
    2,571
    71
    Derby
    +81
    Nope.. unfortunatly didnt work :(
  4. WillieCocker
    WillieCocker
    Sep 5, 2008
    1,533
    Dublin, Ireland.
    +111
    Yes, if you have deleted all the files, they are gone no reset will help.
    I will have to check my One XL to see the file structure if that will help?
  5. sprinty
    sprinty
    Jan 13, 2008
    120
    nottingham
    +12
    Have you ever backed up the TT either with windows or using TT home? If you have used TT home, search your computer for the Tom Tom directory and all the files you need should be in there. the same goes for an explorer back up.
    Otherwise google for tom tom forums, at least one of these may provide you with the files you need, excluding the maps and then when you have re installed the software you will have to use TT home to re install the maps, TT should know from your device code which maps you had.
    Lesson one...... always always, back up your tom tom using windows explorer that way you can keep multiple copies. TT home overwrites its back up.
  6. pointyone
    pointyone
    Dec 3, 2005
    812
    +22
    connect to tom tom home on the net, it will update your unit ,and replace any files that are not there
  7. ant_j
    ant_j
    Aug 31, 2007
    2,571
    71
    Derby
    +81
    Unfortunatly looks like was never backed up.. nightmare.
    Ill get him to connect to net via TT home..
    Not sure if thatll work, but worth a try, the maps are missing too tho :(
  8. Lewie
    Lewie
    Sep 15, 2005
    11,949
    Folkestone
    +950
    I have a V2 does it not come on the sd card or has he wiped that.
  9. ant_j
    ant_j
    Aug 31, 2007
    2,571
    71
    Derby
    +81
    Hi Lewie,
    Yup a case of the entire sd card being wiped.
    Gutted!
