delaying audio, options?
Discussion in 'AV Pre-Amp/Processors & Power Amps' started by spook, May 27, 2004.
  1. spook
    spook
    May 18, 2004
    157
    Hi all, just wondering if my AV amp (5.1) does not have audio delaying capabilities, what are my options gizmo wise, ie between my DVD player and the amp?
    cheers, spook
  2. MarkE19
    MarkE19
    Aug 10, 2002
    17,437
    Rainham Essex
    +2,470
    You may well find it cheaper to buy a receiver that does have the master audio delay feature. The only box that I know of was discussed a while back and I'm not sure if it is available yet, if ever in this country. have a look at This Thread it may help.
    Mark.
  3. John Dawson
    John Dawson
    Jan 16, 2001
    852
    43
    Cambridge, UK
    +112
    Spook - another option is to get a DVD player with audio delay management - all Arcam modern (Vaddis 5) DVD players support this with current player software. That means DV78, DV79 and the older DV88 Plus, DV89 family.
    HTH,
    John Dawson (Arcam)
  4. Andywilliams
    Andywilliams
    Sep 27, 2002
    2,098
    notts.
    +71
    Hi John
    Does that mean you can use any receiver coupled to an arcam and plasma and have no problems with lip sinc.
    Cheers Gonzo.
  5. MarkE19
    MarkE19
    Aug 10, 2002
    17,437
    Rainham Essex
    +2,470
    Yes, an Arcam DVDP connected to any receiver would still give the audio delay, but only for DVD replay. It would have no effect for TV etc.
    Mark.
