harry66
Dont suppose anyone else has had a similar problem?
Have a 32" Widescreen Philips and recently the volume has been acting weird.
Most of the times it responds correctly to the remote control but other times it reacts 10-20 seconds later. When it is working normally you can see the red LED on the TV blinks as you press the volume button on the remote and the volume adjusts.
But when it is acts up the LED on the TV does not blink and the volume does not adjust - but then a few seconds later the volume drops (or increases)!
Have tried a few different remotes including the original that came with the TV but the problems exists regardsless of the remote.
Weird!
Weird!
