Delay times for Yamaha DSP-E800
Discussion in 'AV Pre-Amp/Processors & Power Amps' started by david.garraway, Sep 30, 2001.
  1. david.garraway
    david.garraway
    How do you work out the delay time settings for the rear speakers. I have a Yamaha DSP-E800.
  2. Arthur.S
    Arthur.S
    If you have a poke around the <a href="http://www.dolby.com" target="_blank">www.dolby.com</a> site, you should find a simple diagram for the delay settings. There are different settings for 5.1 & pro-logic. They used to be in the FAQ's. Good luck.
