delay start up avr-1908
Discussion in 'AV Receivers & Amplifiers' started by joo_9989, May 2, 2016.
Tags:
  1. joo_9989
    joo_9989
    Aug 24, 2007
    54
    Malta
    when i switch on my receiver the display works perfectly and commands seem to be responding but no sound comes out from the speakers till almost an hour later and sometimes more!
    this receiver has not been used for a year and has been in a bit of humidity as well.
    can anyone give a suggestion of what could it be? and what one should do to eliminate humidity?
  2. joo_9989
    joo_9989
    Aug 24, 2007
    54
    Malta
    problem changed : distortion from speakers after few seconds that the receiver is switched on. then the sound goes blank...nothing more! any feedback guys?
