cool'n'funky
I've recently bought a dekomount arm for my Mum & Dads 40" LCD TV, having bought one myself just over 6 months ago and been very impressed with it. Installed it myself, and it was (and still is) spot on. No hassle.
We've mounted this one on the wall, and all seemed well. However, the locking mechanism - which I had assumed was an upgrade - is rather a let down, and results in the TV sliding along the bracket when you move it in and out on the arm and rattling. I've been in touch with dekomount, who have been very helpful thus far and there are some bits on the way out to see if this rectifies the problem. I'll report back on this when the bits arrive and I've fitted them.
It's now a week on from installation, and it's sagging. I'm a bit anal about getting things level, so the mount is spot on against the wall. The bracket is perfectly level, and at the time of mounting the TV was perfectly level when mounted on the rail wherever I moved it to. Now it's got sag when pushed back to the wall. When the cantilever is folded one way, it is fine (still level), when it's folded the other way it's way off (very noticeable visually, i.e. without spirit level) - I've attached pics to illustrate.
My question is, has anyone else had this, or have I got a bad one? I've tightened up the joints to be sure it's not just loose (there was a bit more play than I have on mine). Obviously I feel quite bad, as I recommended the mount to my folks! I'll get back in touch with dekomount, as they have been good so far, but I'd like third opinions please!
The spirit level makes it look not so far off, but looking at it without the level and there's a droop of over an inch left to right, so it's really obvious.
Folded back one way (completely level):
Folded back the other way (way off!):
