DEH-P700BT US vs UK models
Discussion in 'ICE, Sat Navs & Dash Cams Forum' started by |DDD|, Feb 13, 2009.
  1. |DDD|
    |DDD|
    Feb 13, 2009
    2
    Greets! :hiya:
    I just recently got the US DEH-P700BT. In doing some research online about getting the unit to work with USB media I came across this page.
    I noticed many users noting that their units were 'cycling through the colors'. The US spec unit does NOT have the ability to change illumination.
    What I am wondering, is if I manage to get my hands on the faceplate for the UK model, will it fit and more importantly, will it work?
    I tried calling Pioneer US tech support and they said that it would not work because the frequencies were different in the UK ( :rolleyes: what does that have to do with a faceplate?!).
    Anyways... any help you all can provide would be much appreciated!
  2. |DDD|
    |DDD|
    Feb 13, 2009
    2
    Anyone? If any of you UK blokes are reading this and have the DEH-P700BT could you be so kind as to post a pic of your faceplate docking area?
    At least then I would be able to compare the pin locations and see if they line up at all. :lease:
