Degraded picture quality through E55
Discussion in 'Blu-ray & DVD Players & Recorders' started by ScoobyWR1, Jan 9, 2005.
  1. ScoobyWR1
    ScoobyWR1
    Hi all,
    I have a minor problem; the picture quality when viewed/recorded is slightly degraded (slight interference/noise/film - if that makes sense) through my Panasonic E55. I had the same problem with my vcr! I am 110% certain that I have all the connections spot on. Any ideas? TV by the way is a Sony IDTV with aerial directly input to this then looped through to my dvd recorder. Could I improve this by buying better RF Loop cables?
  2. JethroUK
    JethroUK
    Dec 5, 2004
    1,141
    You haven't said how you're connected up albeit your r/f and that sounds like your problem - aerial should go source > recorder > Sony TV
  3. johnjackthom
    johnjackthom
    Sep 20, 2001
    713
    46
    Northumberland
    +249
    The Freeview pictures from the IDTV are unlikely to be matched by those from the analogue tuner in the E55 even though the latter are usually pretty good.
    E55 DTT recordings from the IDTV will most likely have the disadvantage of not being made and viewed via RGB connections throughout.
    For flexibility and to get the best results from the E55 you really would be better with a Freeview set top box connected by RGB scart to AV2 of the E55. Then connect AV1 to the Sony TVs RGB scart.
  4. Rasczak
    Rasczak
    Apr 3, 2002
    21,210
    Argyll
    +2,265
    What scart cables are you using? Low quality cables are frequently the cause of interference and are the first thing to upgrade if you have problems. The QED AV21 offers a decent price/performance ratio.
    Yes seconded - get a decent Freeview box (Sony, Pioneer, Panasonic, Pace seem the best) - the advantage of this is you can then leave it entirely configured for recording, i.e. subtitles off, wake up timer set etc, whilst you continue to watch TV 'normally' via the IDTV.
