Def Tech suggestion
Discussion in 'Home Cinema Speakers' started by Samuel040549, Sep 14, 2017.
  1. Samuel040549
    Samuel040549
    Sep 14, 2017
    2
    4
    San Antonio
    I need advice...
    Living room setup with 120inch screen innovations BD screen, but here is the audio setup I'm considering.
    Def Tech 1000 monitors x 4
    Either Procinema 1000 or CS8040 center.
    SVS PS1000 x 1 or maybe x 2
    Onkyo RZ710
    The living room is not ideal for audio, I know... but do you think that this mixture of audio products makes sense? Which center makes more sense?
  2. gibbsy
    gibbsy
    May 17, 2007
    12,402
    3
    Cwm Cynon, De Cymru
    +6,713
    Hello. You have posted your question on this United Kingdom based forum. As such the speakers you have asked about are not familiar to many on this side of the pond. However you should always keep the front three speakers from the same manufacturer and model line to preserve tonal uniformity over the front soundstage. It is also preferable to have surrounds from the same range although I don't consider that to be a deal breaker. Subs can be sourced from any manufacturer.
    May I suggest you post your question on the US based AVF.
