Def Tech speakers
Discussion in 'Home Cinema Speakers' started by philmate, Nov 19, 2000.
  1. philmate
    philmate
    Nov 6, 2000
    216
    Southend-on-sea
    +4
    Hi there,
    Does anyone have the Def Tech Pro cinema 80 or 100 speaker package and if so would you recommend them.
    Philmate.
  2. ReTrO
    ReTrO
    Jul 12, 2000
    3,507
    2
    71
    High Wycombe, Bucks, UK
    +59
    I have the Pro Cinema 80 at work. they are good little speakers, but can be beaten by a set of B&W 601's and CC6. If it is the convenience of size that you want there is nothing to better them.
    The Pro 100's will probably sound better than the 80's anyhow.
    Rick
    'I am just a figment of your imagination.'
    MiB 1997
    Work Site: The Sound Gallery
    Home Site: WD A.V.
  3. SimonSays
    SimonSays
    Jul 26, 2000
    170
    28
    Maidenhead, UK
    +83
    I've had the Pro-Cinema 80's and Sub for a few months now. The Def Tech site used to point to a magazine review which rated them very highly, don't know if it still does though.
    I wanted a sub/sat speaker package because of space/looks (and the sound had to be good too!). I auditioned them against Energy Take 5's and Bose Accoustimas 15 systems and they won hands down offering better base and a wider sound stage.
    So, thats my opinion for what it's worth, but don't just take my word for it, have a listen for yourself.
    Cheers,
    Simon.
    [This message has been edited by Simon_Dugdale (edited 22-11-2000).]
