deepdiscountdvd.com
Discussion in 'Shopping, Deals, Discounts & Bargains' started by cruncher75, Jun 28, 2004.
  1. cruncher75
    cruncher75
    Nov 1, 2003
    1,421
    southampton
    +117
    any one used this site i know if u type in DEEPDISCOUNT in caps u get a 10% discount
  2. Daywalker
    Daywalker
    Oct 17, 2003
    2,180
    Shetland Islands
    +50
    I found the ED2 tin on their website a few months back. I mailed them to check it was in stock and they said they had one left, so i ordered it.
    Waited 6 weeks following despatch confirmation and despite several emails promising it was on it's way they eventually said it had not been sent and was out of stock!
    Not sure i'd use them again :mad:
  3. thesnowman
    thesnowman
    Nov 14, 2003
    271
    +8
    I think DEEPDISCOUNT is a bargain if you live in the US as they are entitled to free shipping
    otherwise its pretty pricey IMO when you add up the shipping cost even with the 10% discount
  4. stamfordblue
    stamfordblue
    Apr 22, 2004
    39
    +10
    They are ok so long as you keep your under to $25 or under.That way you get cheap shipping and no risk of customs.
    Take about 2-3 weeks to get your discs though :(
  5. .scarface.
    .scarface.
    i used them once and never received my dvd's so i wont be ordering from them again, also had to phone them for refund £££, and then the refund amount was less as the exchange rate had changed.
  6. retrof
    retrof
    Feb 28, 2001
    155
    +14
    Avoid like the plague, unless you fancy waiting 3 to 4 months just to get your money back (and possibly lose on the exchange rate). They insisted on re-sending my order which had vanished, and the replacement vanished too. Will never even visit their site after that.
    -rf
