deep discount dvd
Discussion in 'Movie Forum' started by PJONG, Feb 8, 2003.
  1. PJONG
    PJONG
    Oct 7, 2000
    87
    London
    Hello ,
    Has anyone used above supplier, good \ bad experience?
    I'm interested in ordering Glengarry Glen Ross SE at around £6.50, will I have to pay import tax?
    Phil
  2. koku
    koku
    Hi there!
    I have used the very cheap Deep Discount DVD before (only once admittedly) and I got a 6 disc box set worth £46.00 GBP through customs with no trouble at all.
    They have an online account seach too so you can see the status of your order so I'll be using them again if I have another box set order.
    As your proposed order is under £17.99 GBP you should have no trouble with customs as only orders with a value greater than this can be levied with import duty.
    Hope this helps! :hiya:
  3. PJONG
    PJONG
    Oct 7, 2000
    87
    London
    Thanks for the info.
    Ended up going for cd-wow
    cheers
