mephisto123
Established Member
- Joined
- Jan 15, 2006
- Messages
- 86
- Reaction score
- 5
- Points
- 19
Hi there folks. Require some help if poss. Looking for some cabinets to house my AV euip. They need to be deep about 50/60cm, as my Amp and HTPC are large and with all there connections demand those requirements. My current cabinets have the back cut out for these to stick out. Also to fit inside are a SAT box, PS3, Wii and DVD player. To make this unit even more ideal glass doors, so as can keep the noise down but still use a remote. Am about to re-decorate, so the colour/design is not major issue. I know I am asking alot, but maybe some one has had the same issues.
Thanks in advance for all input
