lilomarine
Hello Everyone,
I have a question regarding high fidelity audio.
My current setup is SVS Prime Bookshelfs, SVS PB-1000 Sub & Onkyo A-9050 Integrated DAC/AMP
When i got all these components last week I hooked up the Onkyo AMP via Toslink to my onboard Motherboard audio output. The audio circuitry in this Motherboard is pretty decent. (motherboard: ROG CROSSHAIR VI HERO | Motherboards | ASUS USA)
The sound that is reproduced through the speakers is very clear and very accurate, although the highs/tweeters are a bit harsh. My initial thought was that I could go purchase a sound card (sound card: Essence STX II | Sound Cards | ASUS USA) to be able to tune levels to my liking.
So, I went off to my local electronics store and bought the Asus Essence STX II, thinking I would noticeably tell the difference between on-board mobo audio VS. a dedicated quality HI-FI sound card.
When it really comes down to it, i cannot tell them apart. They sound exactly alike. Also, the equalizer is locked when output mode is set to Optical out.
Was I wrong in assuming that using Toslink, I was going to be able to tell a difference in audio quality?
Or, do I have to be using the Analog output to be able to tell a difference?
Looking forward to your replies,
Thank you
Thank you
