Dedicated centre spkr as rear centre surrnd?
Discussion in 'Home Cinema Speakers' started by Flanners, May 22, 2003.
  1. Flanners
    Flanners
    May 21, 2003
    119
    Kent, UK
    +4
    Can I use a dedicated centre speaker as the centre channel in a rear surround 6.1 setup? Going to use two bipolars as rear suroounds with it? Cheers
  2. Jase
    Jase
    Mar 16, 2001
    9,405
    South Coast
    +856
    Don't see why not, only problem I had when I tried one was the mounting of it. Bit awkward trying to wall mount a centre speaker. I certainly didn't have any problems with the way it sounded. Now I'm using a pair of direct radiating speakers which both sound great and are easier to put on the wall.
  3. Flanners
    Flanners
    May 21, 2003
    119
    Kent, UK
    +4
    Cheers mate just got back from Richer Sounds, drill in hand to put up speakers!
  4. MarkE19
    MarkE19
    Aug 10, 2002
    17,121
    Rainham Essex
    +2,388
    I use a LCR60 centre speaker as my centre rear.
    As Jase said it can be a pain to mount on the wall, but I just got myself a microwave support. Solid (and needs to be with the weight of the LCR60:rolleyes: ) and does not rattle etc. May not be ideal but does the job perfectly.
    Mark.
  5. Flanners
    Flanners
    May 21, 2003
    119
    Kent, UK
    +4
    Yep I have put my LR C6 Eltax rear centre on the wall with some fittings from B&Q! looks ok but the wires down the wall look awful! Have covered the majority with a picture!
