Dedicated CD/MP3 player or Universal Player
Discussion in 'Blu-ray & DVD Players & Recorders' started by dboo, Oct 22, 2004.
  1. dboo
    dboo
    Sep 14, 2004
    28
    I already own a Panasonic HS2. I now wish to buy a player capable of playing CDs and MP3s. While some have advised that a dedicated CD player would be better than a Universal player, I am quite taken by the Pioneer 575 which by all accounts is a good dvd player at a nice price because it also has compent connections which would be an improvement on the HS2. I intend to connect it to a Marantz 7400 receiver and will split it 40:60 dvd / music.
    Advice would be greatly received.
  2. Nobber22
    Nobber22
    Jun 6, 2002
    2,982
    Berkshire
    +111
    Do you want to play CD's or do you want to play them well?
    If the former is all you seek, the 575 is fine. If you want to play CD's properly, get a dedicated CD player; using a budget DVD player is crazy!
    Your Marantz amp is a dandy and sounds very nice in stereo - get a seperate CD player to hear the most out of your music. :)
  3. dboo
    dboo
    Sep 14, 2004
    28
    Thanks. Any particular CD player you can recommend costing not more than £200?
  4. Nobber22
    Nobber22
    Jun 6, 2002
    2,982
    Berkshire
    +111
    Check out www.richersounds.co.uk
    See Marantz CD5400/CD7300, NAD C521Bee or Cambridge Audio Azur 540C. Don't be tempted by the Sony SACD players unless you really want to use SACD's - this players CD playback is a bit lacking IMO. :)
  5. dboo
    dboo
    Sep 14, 2004
    28
    Thanks for your assistance. I will go for the Marantz. I am still having problems deciding on a speaker system not costing more than £500. I have seen the Mordaunt Short Premiere Plus but I am unsure if this will go well with the Marantz receiver for music purposes. Any ideas?
  6. MS-Yam
    MS-Yam
    Aug 12, 2004
    240
    16
    dboo, I used to have the Mordaunt-Short Premiere setup and it was very good musically... 'as far as satellite systems go'.
    If you are using your system for 60% music, I would seriously recommend going for a larger setup, as you will get a much better midrange. Have you looked at the Monitor Audio Bronze range? Even the smallest of the range, the B1, will be far better than the MS setup for music. But ideally the raved about B2 - these are excellent. I was considering the following setup when I was in a similar position:
    B2 fronts, B centre, B1 rears. (available in 3 finishes)
    Try www.hifi4less.com - they do them at a reasonable price. If funds allow, add a sub.
