Dect Modem
Discussion in 'Satellite TV, Sky TV & FreeSat' started by fatbaldbloke, Dec 6, 2003.
  1. fatbaldbloke
    fatbaldbloke
    Dec 3, 2003
    19
    3
    Just getting Sky+ installed.
    Does anyone make a device which you can plug into a sky box or pc modem socket which then uses dect to connect wirelessly into the telephone system? ie like cordless phones?
    I can't find anything but would be a cool invention
    C
  2. WeirdFish
    WeirdFish
    Jun 28, 2003
    881
    Hadleigh, Essex
    +15
    Never heard of one but you can get a bit of kit that utilises your mains ring.
    Here
    Not cheap tho.
    HTH :)
  3. fatbaldbloke
    fatbaldbloke
    Dec 3, 2003
    19
    3
    Thanks!
    Found it elsewhere £20 cheaper. Better for me than having wires everywhere!
    C
  4. WeirdFish
    WeirdFish
    Jun 28, 2003
    881
    Hadleigh, Essex
    +15
    I'd be wary of using one if you've got broadband tho.
  5. fatbaldbloke
    fatbaldbloke
    Dec 3, 2003
    19
    3
    Thats OK. I Live in a village and have community based WiLan broadband.
    Found it for £59.99. If the sky man won't put my telephone cable outside I'll get one of these.
    C
  6. gmt steve
    gmt steve
    Aug 19, 2002
    648
    Manchester
    +6
    BT do a DECT modem(bt.com). You can buy the modem to use with an existing DECT phone or a full phone/base station/answer machine combo. You need Win 98 or higher and a spare USB. They are on sale at the mo' too. Can't use it with Sky obviously, only PC, but unlike the mains device the DECT modem does support 56Kb/s. The most you'll get out of the mains system is approx 28-36 Kb/s.
  7. windfall
    windfall
    Oct 19, 2003
    2,331
    48
    LFC Kop End
    +58
    Quote from weird fish
    Any reason why? I also need one of these found them in Maplin made by one for all at £60. My telephone cable is miles away and we dont want cables, so I was going to get one and use it, but I have adsl..so what effect would this have on the adsl line?
    Tone
  8. WeirdFish
    WeirdFish
    Jun 28, 2003
    881
    Hadleigh, Essex
    +15
    There seems to be a compatability issue with them, sometimes they work generally they dont. It seems to cause the adsl modem to drop sync with the exch.
  9. gmt steve
    gmt steve
    Aug 19, 2002
    648
    Manchester
    +6
    The One for All unit will only support a max data rate of around 36Kb/s.
    That's Kilobits, not Megabits, so it's slower than a very slow thing even with a standard dial up connection. Broadband, forget it.
  10. WeirdFish
    WeirdFish
    Jun 28, 2003
    881
    Hadleigh, Essex
    +15
    Yeh but it will also screw up broadband if you use it elsewhere on the circuit
  11. gmt steve
    gmt steve
    Aug 19, 2002
    648
    Manchester
    +6
    Sorry mate, I didn't realise what you meant.:blush:
  12. WeirdFish
    WeirdFish
    Jun 28, 2003
    881
    Hadleigh, Essex
    +15
    No prob, sometimes you write somit one way but someone reads it different.
  13. gmt steve
    gmt steve
    Aug 19, 2002
    648
    Manchester
    +6
    Still love tunafish sandwiches, by the way? I know that tigers will do anything for a tunafish sandwich.:D
  14. WeirdFish
    WeirdFish
    Jun 28, 2003
    881
    Hadleigh, Essex
    +15
    :laugh:
