Dodgexander
I am looking for a way to record in HD and to be able to archive these recordings to view later on my media server.
I understand its in the specification to encrypt HD recordings which is why most STB`s support the transfer of SD recordings via USB/Network only.
I wondered if anyone could suggest the best way to do this. Perhaps someone on here has better knowledge than me.
Possible options:
Humax HD/HDR FOX T2 with custom firmware. The HDR being the easiest to do this with as you can run decryption in the background.
PCTV Nanostick 290e T2 or the Blackgold BGT3620 . Can't for the life of me find out if HD Recordings can be transferred after recording with these. Does anyone know? Is there pc software to decrypt?
Obviously if anyone else has any other suggestions they would be welcome.
Apart from the ability to transfer recordings the other must have for me is the Transcoding of HE-AAC to Dolby Digital. I know the PCTV stick supports this using its own software but not media centre. I also know the humax boxes support this too. Just unsure about the BlackGold.
Possible options:
