Decorators broke my Panny - and I'm glad
Discussion in 'Plasma TVs Forum' started by absthechatter, Apr 27, 2005.
  1. absthechatter
    absthechatter
    Nov 27, 2004
    159
    Had my lounge decorated and the rather careless decorators broke my PW6 whilst taking it off the wall. The reason I'm glad??? There are two of them......
    1. They agreed to compensate me with the full purchase amount I paid, which has no resemblance to the prices now (in my favour).
    2. Even though they have not paid up yet (insurance agreement received though) I went out and bought myself a new PW7 and I'll still have another £1200 left for some more updating. Upon switching the PW7 on for the first time, the realisation hit me that there had been something not quite right with the PW6 I had been using for just over a year, even though it had been calibrated twice. I had considered the PW6 to have an excellent picture, but comparing it to the PW7 is like night and day. I must say with a big smile on my face that the PW7 is superb :D .
    I currently have it connected to an iscan HD+ through the VGA port. I have the PW7 set to Cinema to keep contrast down. The Iscan is set to output at 720p at 60hertz. Do I have these settings correct and are there any other settings I should make sure I have on the Iscan, ie low numbers for contrast, brightness so I do not ruin the effect of setting cinema on the Panny?
  2. MAW
    MAW
    Jan 24, 2002
    14,103
    Nr Dorking
    +411
    If you are connecting to the VGA port, you can do 720p at 50Hz for PAL, and 60Hz for NTSC. So lock your 50Hz to 50Hz, or perhaps 75Hz if 50 gives you grief, I have known it. This will avoid the infamous FRC judder.
  3. absthechatter
    absthechatter
    Nov 27, 2004
    159
    Many thanks. At 50Hz, the picture is excellent, but only takes up about half the screen, and I can't get it to move!!! At 60Hz, the screen is filled, but I get that feeling that there are bits being hidden, as though I need to shrink it a little. I want to get it calibrated (ISF this time) but want to leave it a little while to settle first.
  4. MAW
    MAW
    Jan 24, 2002
    14,103
    Nr Dorking
    +411
    Try 50-75Hz then, being a multiple of 25, this works too. That's what I referred to above, sometimes it makes a difference what order things are turned on in, sometimes you can get 50Hz to work like that.
  5. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    So abs how does a PW7 compare to your LG?
  6. absthechatter
    absthechatter
    Nov 27, 2004
    159
    It's better!!!
    Still think the LG picture is excellent though, just not superbly, doubly excellent. And it is more user friendly for the family.
    I must have had a dodgy PW6 from the beginning - although dodgy is probably the wrong word, it was extremely good (better than previous CRT) and I was more than happy with it - but I am glad it got broken.
    The PW6 was my first plasma so I had nothing to compare it to. The picture I had at home was much better than any setups I saw in the shops when viewing so I did not realise there was so much extra potential there.
    My problem now is what am I going to spent the extra money on!!! I really should update my current £250 home cimema setup and get some decent sound to match the picture......... or do I get another screen to go in the bedroom - there's nearly enough money left.
    It's gonna have to be sound!! Amp and speakers, here (hear) we come.
  7. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    DONT forget ISF...........
  8. absthechatter
    absthechatter
    Nov 27, 2004
    159
    I have it planned. How long would you suggest befor I have it done? Shiny new panel is now 2 days old.
  9. Jazz Monkey Jr
    Jazz Monkey Jr
    Jan 10, 2005
    14,242
    2
    4
    137
    Garstang, Lancs
    +1,625
    200 hours normally
  10. dilsher
    dilsher
    i will third that ..ISF in da area!!!! :thumbsup:
    dil
  11. FaxFan2002
    FaxFan2002
    Jan 25, 2003
    2,432
    63
    Andover
    +160
    you can get a 37" panny 7 for 899 (see other posts) for the bedroom!
  12. Mep
    Mep
    Dec 25, 2004
    9,673
    Surrey
    +477
    ...........or you could buy me an Iscan too! ;-)
  13. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    I'm in line after mep... (Iscan HD would do nicely, not bothered about a HD+ :D )
  14. Mep
    Mep
    Dec 25, 2004
    9,673
    Surrey
    +477
    yes I'll settle for HD too abs if that makes your decision easier :D we could always do a time share Horny! :)
  15. dilsher
    dilsher
    ..Ok then can you pay for my Lumagen HDP???
  16. adymartin
    adymartin
    Jan 27, 2005
    130
    16
    sorry but it seems everyone has forgotten to say......
    you spawny bast......!!
  17. Mep
    Mep
    Dec 25, 2004
    9,673
    Surrey
    +477
    oh yes!...bloody good point ady :)
  18. absthechatter
    absthechatter
    Nov 27, 2004
    159
    And then some..... :D
    And any spare iscans whether + or not, will only be given with the missus included, and believe me that will be much more expensive than buying one yourselves (and the Iscans better to look at :devil: )
  19. PRITCH
    PRITCH
    hey! send those painters around to my pad.Tell them to hit the back of me ford cortina on the way up the drive, ram it into my leanto garage, put the step ladder through the b&w 12" portable and knock the missus out while falling from the ladder.
    Then i can have a new lamborghini in my new garage and watch my new 69" plasma with me new missus.
    tell them my number is:- 07956291765 and they can start yesterday
    thx
