decking lights
Discussion in 'General Chat' started by liveforav, Feb 23, 2013.
  1. liveforav
    liveforav
    Sep 26, 2005
    1,450
    Uk
    +315
    Not sure if this is the right section, but im looking for suggestions on recessed decking lighting.
    Im wanting to get somthing thats flush, or almost flush fitting thats also quite bright. Im not wanting mains powered as that will involve an electrician and new circuit etc, so solar power it is.
    Ive seen loads of lights with the solar cells built in but by all accounts theyre crap. Im wondering if anyone has seen good ones? Or alternatively do any decent ones exist that plug into an external solar panel?
  2. tvmcp
    tvmcp
    Oct 2, 2009
    1,236
    Basingstoke
    +220
    Why not just use 12V lights, you can do all the wiring outside, and just need transformers, which could be plugged in if you don't want to hard wire them.
  3. liveforav
    liveforav
    Sep 26, 2005
    1,450
    Uk
    +315
    Thought of that but i dont have an external socket and dont fancy trailing cables through windows or doors etc
  4. jonna
    jonna
    Mar 25, 2002
    3,209
    Cheshire
    +2,530
    I used Blagdon powersafe. The cable for you lights uses one of these Blagdon PowerSafe Outdoor Plug and Socket Cable Connector: Amazon.co.uk: Lighting
    This is plugged into this http://www.amazon.co.uk/Interpet-Ltd-PowerSafe-4-Outlet-Switchbox/dp/B0010ANYAM/ref=sr_1_3?s=lighting&ie=UTF8&qid=1361691448&sr=1-3
    Then a cable from the above box runs into your house ( one hole) and a standard plug is fitted onto it, then plugged into this Blagdon PowerSafe Water Garden Circuit Breaker: Amazon.co.uk: Lighting then just plug it into your indoor socket.
