Decisions Denon 3803 or HK 5550 ?
Discussion in 'AV Receivers & Amplifiers' started by scollops, Jan 14, 2004.
Tags:
  1. scollops
    scollops
    looking to complement my Plasma TV and DVD (HK) both progressive scan compliant.
    Which one should I be looking at - I thought the denon was the best option until I spoke to another store. Any one out there who can put in a couple of pence worth ???
  2. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    Personally i like the HK stuff it will match your DVD and the amps remote will operate the DVD for you. What speakers are you looking at? Will you use amp for video switching???
  3. scollops
    scollops
    I was looking at getting the Kef 2005.2 unless any other recommendations - dunno if to make 6.1 surround. As for switching, thought about that, I believe the Denon has dedicated full Mhz setup dunno much about the HK.
    Is there a big difference, I will have sky plus too soon. May also get an Iscan Ultra (HD if I win lottery)
    Still trawling web for best package offers for both :rolleyes:
  4. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    Dont the trawl the web mate get to your local dealer, I would reconmend a demo with infinity Orues IMHO they are as good as if not better than the KEF eggs.
    Go have a listen and a look and see what you think.
  5. scollops
    scollops
    Cheers Horny Dragon - what about the amp /switching etc ??
  6. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    AVR4550/5550 do 2 component 5+ S-video with loops and composite i dont think it does up conversion but it is IIRC full bandwidth.
  7. scollops
    scollops
    Thanks again - still dunno which amp though, any major factors ?
    Also is it worth buying the additional speaker for 6.1 or not ?
  8. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    HK is 5.1/6.1/7.1 selectable, a lot of people like the 6.1 sound and say it does add to 5.1, no 7.1 sources at the moment but they do have logic 7 that will allow 5.1 to be sampled to 7.1 very effectively.
  9. jmack
    jmack
    the audio delay on the 3803 is a big factor if you have a plasma its a big plus.
    cant comment about the other amp
  10. wilber
    wilber
    Sep 29, 2002
    1,970
    +30
    Have you listened to the amps - It's a lot of money to spend on the say so of shops and people like us!
    If you're in 3803 territory, I'd add in Pio Ax3 & Yamaha rxv1400 (another amp with audio delay and component video switching)
  11. Brox
    Brox
    Oct 26, 2000
    313
    16
    Marlow, Bucks, UK
    If you have a demo I expect there would be a lot of people interested in your views, personally I would expect the HK to be much better in stereo and and possibly a little better in av.
    But then i'm a an HK fan - but the HK would be better in stereo, i'm fairly sure of that.
  12. scollops
    scollops
    Cheers guys... off for a demo of 3803 and HK within the next day or to - give em time to set it up.
    Hopefully get some good feed back.
    :smashin:
  13. ddlooping
    ddlooping
    Oct 7, 2003
    1,446
    Essex
    +27
    Hi all. :)
    scollops, could you share with us the results of the demo? ;)
  14. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    he didon another thread and decided on HK instead of denon in the end. ave a search.
  15. ddlooping
    ddlooping
    Oct 7, 2003
    1,446
    Essex
    +27
    Thanks hornydragon, I have probably read it then. ;)
