Decisions decisions!!!!!!
Discussion in 'Home Cinema Speakers' started by willygbr, Mar 19, 2006.
  1. willygbr
    willygbr
    Ok,
    After much thinking about new fronts. The following which will stay in my budget. Presently have as follows:
    Yammy 757
    Fronts MS 302
    Centre 905i
    Sub 909w
    Denon 1920
    Choices as new fronts with 302's going to rear.
    MS 902 £90
    MS 902i £150
    MS 904 £140
    MS 914 £270
    MS 906i £250
    All in order of price, from £90 for 902's to £250 906i's. £250 the max I can spend but unsure on how each of these would integrate into current system. But also want value for money as well!! Offers anyone?
    :thumbsup:
    Iain
  2. willygbr
    willygbr
  3. Beobloke
    Beobloke
    Aug 10, 2004
    1,315
    Out in the Sticks!
    +67
    Personally i'd stick with a pair of the new 'i' Avants as they will match your centre speaker better and are a considerable improvement over the older non-i Avant speakers and the 914's.
    From your list you are then left with the choice between the £150 902i and the £250 906i, although you should allow another £70-£100 for stands if you go for the 902i's.
    You can then let the deciding factors between these 2 be your ears and the good old WAF!! :D
