Well after reading various forums and fliting between plasma, lcd and pj I finally after some arm twisting from my father I bought a Z3 blind. I've never used or had a pj before (only seen them used for presentations) but for the price I thought give it a go
It arrived yesterday - good service from ivojo
(my room isn't finished yet) so we just stuck it on the kitchen table - got a piece of painted mdf (I'm making a fixed mdf painted screen for the wall as my image size is smaller than most) and fired straight at it (I know mr amateur
). We hooked up a Panasonic E95 via component and made sure progressive scan was active.
I don't know what to look for in terms of VB/Screendoor and all the other problems but to myself and my father the picture gobsmacked us. With no settings being changed on the unit it was very very impressive (far better than I had expected). Fired up T2 and the start sequence with the fire was excellent - heh no sound otherwise I might have ended up watching it all
I even ran normal TV through the E95 (rf) and that was pretty good aswell - I think my original aim of keeping the Z3 for Console,DVD might change after seeing footy/cricket
I didn't think the noise of the unit was bad either - I'm used to a 4 fan PC so once some sound is on the PJ won't be heard I'd imagine.
Overall for myself I'm chuffed to bits but thats maybe just the PJ and big image part of it
but I decided on the Sanyo over some of the others based upon price, general reviews, warranty and also the fact that if it wasn't to my liking I could probably sell it for a not massive loss. I had considered the Sony but it was a fair bit more and I thought I could use the difference towards a HDMI equiped DVD player (3910 most likely) - the more I was going to spend blind the itchier feet I get
Its packed away now till my room is finished but I think work on my room might progress a bit quicker now
Hope my 2peneth helps a little.
