Decision Time - Which Recorder Panny DMR-E85 or Tosh RD-XS32 ?
Discussion in 'Blu-ray & DVD Players & Recorders' started by ianrob, Nov 16, 2004.
  1. ianrob
    ianrob
    Hi all,
    I have been reading your messages regarding the panny 85 and the
    tosh 32, the published reviews and the online manuals. However, there
    doesn't seem to be much in it either way, therefore I would appreciate
    your opinions on which you believe is the best option. :lease:
    Thanks :thumbsup:
  2. Rasczak
    Rasczak
    Apr 3, 2002
    21,687
    Warwick
    +2,560
    This is a regular question and the answer is that they are both excellent machines - you won't regret it whichever one you get.
    In the Panasonic's favour is the (slightly) better recording quality and the fact that it's 'complex' features are easier to use than the equivalent on the Toshiba.
    In the Toshiba's favour is iLink (useful for a Digital Camcorder), DVD-RW support and more DVD authoring options.
