Deciding on low budget amp (up to £300)
Discussion in 'AV Receivers & Amplifiers' started by thecornflake, May 3, 2007.
  1. thecornflake
    thecornflake
    I've narrowed down a list of amps in readiness for my new Tv, which will be a 32 or 37 inch HD Ready LCD (although I won't be using HD stuff straight away, just normal Sky and DVDs).
    I'm having trouble deciding, hopefully you can help me choose. The list is -
    Samsung AVR710
    Sony STRK880 (can't find anything out about this but it's £250 and had HDMI)
    Denon AVR1507
    Yamaha RVX359
    It will also be used for music, but not much - mainly content streamed in from a digital media adaptor from the PC.
  2. ChristianBeccy
    ChristianBeccy
    Nov 20, 2006
    297
    +17
    In my long and seemingly endless search for an Amp my budget has increased slightly due to extra features that I think I would like to have.
    However, for under £300, I think there is no doubt that the Yamaha DSPAX759SE is the way to go......
    http://www.superfi.co.uk/index.cfm/page/moreinfo.cfm/Product_ID/2861
    Seems to tick all the boxes, but for me, the lack of HDMI and my fear of needing that has pushed me up to the £400+ price bracket.
  3. ChristianBeccy
    ChristianBeccy
    Nov 20, 2006
    297
    +17
    Incidentally, most people are telling me that I don't really need HDMI. ;)
  4. sk8
    sk8
    Sep 19, 2006
    556
    B&NES
    +17
    unless you realy want need two in one out then no not really. I bought a 2307 but don't have a HD TV so my HDMI connections are redundant!
    Originally went in to buy a 1907 but you know how it is
    What about an Onkyo 604?
  5. hornydragon
    hornydragon
    Dec 19, 2001
    28,345
    +1,218
    Onkyo 604 or 674 would be ideal 674 over budget has upconversion to HDMI 604 has up conversion to componenant and HDMI switching 2-1 also fantastic AMP at silly prices
  6. sk8
    sk8
    Sep 19, 2006
    556
    B&NES
    +17
    they are great value for money :thumbsup:
  7. coliam
    coliam
    Feb 18, 2007
    154
    +13
    I was in a similar situation and went for the Yam DSP-AX759SE at £240 :thumbsup: , also you might find the
    compressed music enhancer useful for your streamed mp3s etc....
  8. thecornflake
    thecornflake
    I'm interested in where you got it for £240 - I'm looking at £300 on Richer sounds unless I've got the wrong model.
  9. Barbs
    Barbs
    Oct 2, 2006
    457
    Belfast
    +20
    A quick google and you get:
    £249 - http://www.superfi.co.uk/index.cfm/page/moreinfo.cfm/Product_ID/2861
    £229 - http://www.digitaldirect.co.uk/prod...asp?product_id=11242&referredby=STEAK#Scene_1
    £240 delivered - http://www.soundandvisiononline.com/moreinfo/index.asp?product_id=11242&referredby=STEAK
    Take anyone one of these into RS and they should price match.
  10. thecornflake
    thecornflake
    Thanks. I've narrowed it down to the Denon 1507 because of fantastic reviews and the DSP-AX759SE. Any edge one of these has over the other? I'm more interested in quality sound for movies than music as that's what I'll mainly be using it for.
    The speakers I'm looking at are the Tannoy FX5.1 -
    http://www.richersounds.co.uk/showproduct.php?cda=showproduct&pid=TANN-FX5.1-SIL
  11. dougan
    dougan
    Jan 12, 2005
    544
    Devon
    +11
    The Tannoy's are the old model, they have been superceded by the EFX5.1's, which are £250 at Richer, you can get them for £200 if you shop around.
    The EFX's have a redesigned centre speaker and a better looking gloss finish,
    dougan
  12. dowzer
    dowzer
    Oct 21, 2006
    1,658
    +252
  13. slowpoke
    slowpoke
    Jul 11, 2005
    1,091
    41
    Maidenhead
    +18
    I have the older tannoys running with a yamaha640se amp. Both will be for sale soon. I dont think its worth running any of your amp choices with the tannoys as they have been around quite a long time now and wont give justice to the new amps. Have you looked at any of the canton range from the power buy?
  14. slowpoke
    slowpoke
    Jul 11, 2005
    1,091
    41
    Maidenhead
    +18
    Sorry, was alos going to add, the Onkyo for £300 is an absolute steal with HDMU switching. If tha is your budget its a no brainer IMHO
