Question Deciding if this room is suitable for Home Theater
Discussion in 'Home Cinema Building DIY' started by hebbocake, Aug 18, 2018.
  1. hebbocake
    hebbocake
    Aug 18, 2018
    2
    4
    Netherlands
    At the moment I've a relatively old HTiB set from Harman Kardon which just about fits under the tv. I am satisfied with the sound, but the right speaker is distorting because of a fall and I'm suspecting a custom set of speakers/sub/receiver would probably sound much better anyway, right?
    I'm just asking if it's possible to have a proper setup (5.1)? with this space or if it's better to find a different room for the home theater needs.
    Here's a few pictures of the room/corner in the room. Imgur
    The sub is normally next to the couch in the corner.
    If you want to find speakers to recommend, I live in the Netherlands. But my main question is if it's achievable with this space. I don't think there's enough room.
    Budget for the whole audio schebang is around 1200 euros, preferably 1000 euros, though.
  2. Thug
    Thug
    Jul 17, 2003
    7,854
    3
    Middlesbrough
    +3,976
    Nothing wrong with that space, its larger than my cinema room with 5:1:2 sound.
  3. hebbocake
    hebbocake
    Aug 18, 2018
    2
    4
    Netherlands
    The room is large, but there isn't much room for proper speaker placement. Is there?
  4. Killbill118
    Killbill118
    May 12, 2017
    152
    4
    Birmingham, United Kingdom
    +51
    Perhaps look at inwall discreet speakers for a 5.1.2?
    You need speakers that had disperse sound really well and give you a good sound stage. Kefs maybe..?
