Decided on TV card, what about software?
GeorgeStorm
As above really, don't have a clue what I'm doing
I'm planning on building a media pc for the family to go with a new tv
Aiming to replace the current HDD recorder they use
Current spec:
Some media case (looking at silverstone lascsala since it seems to be the cheapest which supports full atx boards)
msi 790 platinum
e4300
4gb ddr2
750gb WD HDD
Some tv card?
Looking to be able to record one channel while watching another, preferably record two while watching another.
We have digital tv and freeview, no sky etc and obviously analogue has been stopped in the UK.
Looking for both recommendations to cards, and to whether this is the best way to go about it?
Am looking to replace the black box, be able to watch iplayer on the tv, be able to save recorded files with actual names rather than just a number and a date which it is at the moment etc
GeorgeStorm
I'd want to be able to record hd content, so I guess the BlackGold would be the one to go for?
What's the difference between the BGT3620 and BGT3630, since they are the same price on scan
And so I can just plug in the arial, and then watch, record tv on the computer? Never used anything like this before, so sorry if the questions are obvious.
spyder viewer
The BGT3630 is a single dvb-t2 and a single dvb-s2 tuner. The bgt3620 has 2 dvb-t2 tuners only. The simplest way to use either card is with W7WMC (all I ever use). HD content takes up a lot of disk space (probably 2gb per hour). SD is half that. Not sure if your E4300 will be able to process all the data if you end up recording two HD channels while watching a third but it should be fine for SD (which is all I use).
Add something like this and I'm pretty sure you'll be well pleased. Windows Media Centre Remote Control : Remote Controls : Maplin Electronics
robbo100
Wait, so I can record two channels and watch a third with the 3620? (all hd in theory)
It depends upon what software you use. With WMC, you will be able to watch or record a single channel for each tuner you have. So both the cards you are looking at have 2 tuners (of one type or another), so you can watch one and record with another, or record using both.
If you use other software (I know MediaPortal does this, but I am not sure what other software also does it), you can record the whole mux using a single tuner (a "mux" is effectively a "frequency" and there are a number of channels broadcast on a single frequency - you can see here that Sandy Heath (DVB-T2 transmitter broadcasts 6 frequencies Freeview on Sandy Heath TV transmitter | ukfree.tv - independent free digital TV advice). With DVB-T2, all the HD channels are broadcast on the same frequency, so you can record them ALL with a single DVB-T2 tuner (BBC HD, BBC One HD, Channel 4 HD ITV1 HD). Leaving your other tuner to watch or record other SD channels.
I personally wouldn't worry about an E4300 being underpowered for recording more than one HD channel, it is more down to your motherboard throughput and HD capacity than processing power. I would think you could record all 4 channels simultaneously without too much problem.
You main worry is that the graphics card might struggle (I can't see what one is fitted to the mainboard). You may benefit from installing a PCI-e graphics card such as the ATI 5450, which will be easily powerful enough for playing back HD content.
Robbo100
GeorgeStorm
Ah ok, and cpu wise, can always overclock it, and even possibly replace it with a quad if worst comes to worst. (the chip can do 2.7 with no effort)
Gpu wise, I've got various cards sitting around, including an 8800GT, which I'd be tempted to just shove in, then wouldn't have any problems surely?
And I think it will start with a single 750gb HDD, not sure though.
robbo100
To be honest, an 8800GT probably isn't enough if you ever intend to watch bluerays, but should be just enough for HD TV, however because your processor is a bit on the slow side, you might want to aim for something a little quicker. I would just give it a try. Does the 8800GT have HDMI?
I have an 9600GT with an E7400, and it is fine (my other PC is a slightly quicker AMD XII 265, with an ATI HD5450 which is perfect.
A single film recorded off HD TV takes about 10 gig, so a 750 GB drive will not give you a massive amount of head room, but it is a good start. You can always add another drive in at a later date if you need it.
Robbo100
GeorgeStorm
Yeah, only reason just looking at 750gb drive atm is because we already have it, and with current HDD prices, although they have come down a little, I'd rather wait before investing in some 2tb+ drives.
And about the 8800GT, really? I guess I'll have to do some testing, and no I don't think it does, so looks like may have to invest in a new gpu aswell, was hoping to keep it cheap for the family :/
Although, why would the 5450 be better? (considering it's a far weaker card? :/)
robbo100
the HD5450 can be picked up new for less than £28.
Why do you say that the 8800GT is a better card than the 5450 (why is it a "weaker card")? The 8800GT is about 4 years older than the 5450.
The 5450 is far more powerful, is DirectX11 and output HD Audio over HDMI. The 8800 doesn't even have an HDMI cable. You can get better cards if you want to spend more money, and you can get NVIDIA equivalents for about the same money if you prefer.
GeorgeStorm
I was referring to actual graphical processing power, Dirext11 won't help with video playback (as far as I'm aware), only thing it does have is HDMI, which is a fair point.
Habanos
The 8800GT is considerably faster than the 5450 in terms of processing power. It doesn't have as many video decoding features (although it still decodes MPEG2, VC1 and h.264) but it's more than good enough. I used one with a 2.0GHz Athlon 64 X2 for playing Blu-ray without any issues.
The only downside to it is the power consumption.
GeorgeStorm
I wasn't there to correct you, since I wondered if it was to do with encoding, merely stating why I'd said what I did :)
Yeah, I'll probably end up going for something like a 5450 anyways, since it doesn't have a HDMI port as far as I'm aware (will double check later when I can be bothered to find it) and as Habanos said, power consumption will be considerably higher :/
GeorgeStorm
And back to the tuner front, so will the family still be able to watch TV using the TV's built in tuner? At the moment they can use the 'black box' or the TVs own tuner, so in theory, we would be able to record two separate things (say BBC1 HD and Dave) using the blackgold card and then watch ITV using the TVs tuner?
robbo100
You need an antenna cable plugged into each tuner you use, irrespective of whether your tuner is in your PC, the TV or is in a set top box.
You asked if it was still possible to watch TV using the built-in tuner and the answer is yes, as long as that has an antenna plugged into it (you will also need an antenna cable connecting to each tuner in your PC.
Habanos
Terrestrial signals (unlike satellite) can be split.
If you're in a post-DSO area, you may be able to get away with a Y- or T-splitter to share the signal between the TV and the computer. If not, a distribution amplifier or multi-output "signal booster" (but only a low gain one) should do the job.
spyder viewer
If you currently have no issues with tv reception, then a simple low loss splitter from any high street "tv" store will do.
GeorgeStorm
Right, well I think I might go ahead and order some new shinies today :D
So the setup will be:
e4300
msi platinum
4gb ddr2
430 tagan PSU
30gb OCZ SSD (they won't want to leave it on all of the time, so fast boot times are a must)
750gb WD HDD (just to start with)
undecided on the gpu front
silverstone lascala
blackgold 3620
All with whichever TV the parents end up buying :p
So, onto the software front, was thinking linux since I want them to be able to use it as a normal pc aswell as just a media centre type pc, but don't want to pay for windows, and parents don't like pirating.
So, say I were to use fedora (my personal favourite distro) then what would be best for the whole media centre front, xbmc?
robbo100
XBMC won't play live TV from your Blackgold 3620. I believe you can install a hack to allow it to play TV from the MythTV or MediaPortal TV Servers, but I don't know anything about how to set this up. Also, if you plan to use this hack to play live TV using the MediaPortal TV Server then you will need to run the MediaPortal TV Server on a Window PC.
Robbo100
Habanos
Take a look at OpenELEC. It gives you XBMC configured out of the box, and also includes the PVR support (but TV/PVR support in XBMC is not remotely close to 7MC or MediaPortal yet)
spyder viewer
You'll have to leave it on (or in standby) or it can't record.
Junk the SSD and buy W7HP, then run WMC. Unless they don't need it until next Xmas?
or run mediaportal under XP.
Podcast: CES 2021 Special - Sony, LG, Panasonic, Samsung, TCL and Hisense TV news and more...
Latest News
iFi Audio launches iDSD Diablo DAC/Headphone amp
  • By Andy Bassett
  • Published
Samsung launches Galaxy Buds Pro
  • By Andy Bassett
  • Published
Samsung launches Galaxy S21, S21+ and S21 Ultra smart phones
  • By Andy Bassett
  • Published
Mola Mola debuts Kula integrated amplifier
  • By Andy Bassett
  • Published
TCL announces TS8132 soundbar
  • By Andy Bassett
  • Published
