Decent TV Aerial Cable?
Discussion in 'Cables & Switches' started by Andy_t, Feb 16, 2005.
  1. Andy_t
    Andy_t
    Jun 29, 2004
    69
    Will it make a difference if I buy a decent TV aerial cable to go from a booster to the TV?
    I live in a rented house and the TV reception is pretty poor from the rooftop aerial but we now need a booster to send the signal into a PVR PC as well as the TV. Therefore I was wondering if a decent aerial cable (say more than £15) will make that big a difference between the booster and TV?
    Has anyone got experience of these cables? I'm usually of the opinion that if you spend a bit more on a cable it will definitely be better than the freebie leads you get, but in this instance I'm not convinced as our reception isn't brilliant anyway.
  2. Flimber
    Flimber
    Sep 22, 2002
    13,723
    Yorkshire
    +4,484
    Probably no difference whatsoever. If your signal is less than A1, there's not much you can do about it afterwards. "Boosters" are a mixed blessing.
    Mike.
