Decent Running Machine / XTrainer For £200?
Discussion in 'General Chat' started by monkeyleader, Feb 12, 2009.
  1. monkeyleader
    monkeyleader
    Jan 13, 2002
    2,621
    71
    Cambridge, UK
    +87
    Hey - the old knees and the crappy weather but I want to get back into running .. was thinking about a running machine, and I can see you can pick them up quite cheap - but they also look like they would fall apart as soon as you would get on it.
    Any chances of picking up a decent runner or X-Trainer for £200 ?
    Nige
  2. Iccz
    Iccz
    Apr 29, 2008
    24,060
    Keystone City
    +6,750
    Your trainers will fall apart before most cross trainers, personally i'm a huge fan of running in the outdoors, I only ever do roadwork or crosscountry, I like the varies in incline and surface.
    I'd recommend an elliptical trainer as opposed to a normal running machine, however I can't recommend any certain ones. Maybe others can!
  3. The Dude
    The Dude
    May 21, 2004
    6,772
    Beverley, East Yorkshire
    +3,241
    If your knees are dodgy then I'd say go for the cross trainer, can't offer any recommendations though...
    however, do you have a push bike?
    you can pick up a set of rollers or a simple trainer for around half that price I'd expect. :)
  4. Philly112
    Philly112
    Oct 17, 2003
    4,446
    Frodsham
    +1,845
