Decent Multi region upgrade for Tosh 210E
Discussion in 'Blu-ray & DVD Players & Recorders' started by Noel, Oct 21, 2001.
  1. Noel
    Noel
    Dec 18, 2000
    421
    +8
    Hi all,
    I've just picked up a bargain I couldn't refuse. The above player was £119,99 at Costco, region 2 only. I needed a second player for the living room but I also need multi region. Who does a good collection/install/delivery service which gets around Macrovision and RCE? Techtronics claim to, but I've seen some other posts about their service, so I may steer clear....
    Thanks in advance,
    Noel
  2. kenfowler3966
    kenfowler3966
    Jul 23, 2001
    844
    19
    leeds UK
    +15
    Not such a bargain when a decent conversion by someone like DVD Magic will cost about £80 and will void your warranty. THere is no kit from them for this model to DIY so you also have to get it to them to have the work done.
    Cheaper and better to get a modified player initially which wil come with a warranty. :confused: :confused:
  3. pcavelle
    pcavelle
    Jan 23, 2001
    985
    London
    +16
    Hi Noel - I bought a 210e from DVD Magic & was informed by them (Ashley, I think the chaps name was) that all 'chipping' on the Toshibas is now a firmware update only ie no circuit boards or soldering involved at all. They just run a CD they get from a software co. somewhere, which changes it to auto multi region & gets round RCE too apparently.
    Why don't you try them first & see if they'll do it for you?
    Paul
  4. Noel
    Noel
    Dec 18, 2000
    421
    +8
    Thanks Paul, in the end I got it done at a place in Manchester for £20! Your were right about the firmware only upgrade and RCE is no problem. I think I did quite well to get a multi region 210E for £139...
    Thanks again for the reply,
    Noel
