Decent Micro ATX Motherboards with SPDIF out for Athlon 64 (Socket 754)?
Discussion in 'Computer Components' started by tk2001, Dec 4, 2004.
  1. tk2001
    tk2001
    Nov 4, 2001
    1,378
    48
    +36
    I am currently looking for a decent high-quality Micro ATX motherboards with SPDIF outputs (coaxial digital outputs) for the Athlon 64.
    The only one I have come across is the Gigabyte GA-K8VT800M Micro ATX (Socket 754) but unfortunately that doesn't have SPDIF out.
    Are there any other motherboards out there that fit my needs?
  2. mark88
    mark88
    Oct 25, 2004
    878
    +23
    I don't think you'll find one. I ordered the gigiabyte just recently because there simply isn't any other mATX 754 boards with SP/DIF or Gigabit Lan. The gigabyte does have a SP/DIF header on the board, but not a I/0
    DFI do make one, the "infinity" but you will not find it for sale in the UK.
